If there's no belt routing diagram under the hood, make sure you sketch out the pattern before you pull the old belt off, it can save you some time. And keep the old belt for a trail spare/backup. There are belt removal tools that fit in the tensioner hole, but with as much space as you have in a K5, a ratchet is fine. Or you can muscle it by hand if you are inclined.
