hey man, I'm so sorry I dropped the ball on your PM... little nuts this time of yr, but no excuses...
I see this thread is sorta/kinda related to the PM.... I'll try to cover everything here....
Fordum is right, I know it may seem silly, but car parts in boats can be very very dangerous... it'll work, it may work for a long time without incident, or it unfortunately may not..
in this case, dizzy's... the key to a marine dizzy is the fact the vent is flame arrested.. marines used to have brass contacts, but not anymore really.. they also run gasketed caps... there is a reason the Coast Guard has the requirements it has... this sh*t has happened..
I know most of you are going "ah, how important can it be", etc, etc... well, I'll tell ya, therer's a reason boats have blower vents, gas fumes in a bilge are no joke.. you forget to run the blowers, fumes, you light motor off, boat goes boom... I see stuff like this on boats, and the presses stop... I cannot in good conscience as a mechanic let things like that go... living with myself after letting Bob, Jane and child go out and BBQ themselves is not one I want to live with...
anyway.. enough of the safety lecture... why can't you get to the crank? got a raw pump attached to the front of it? 3 bolts to take it off usually.. what marine package is this?
keep in mind, most packages have a window on top of the flywheel cover at the back of the motor.. usually you can get a prybar in there... also, if the plugs are out, most motors can be turned over by hand by just grapping the engine belt in 2 locations and turning the motor over a bit at a time... no sh*t...
obviously your gonna need to drop a timing light on it once you light it off......
as to a book per the pm.. for some stupid reason I seem to think I have a book at work that covers those boats... why, i have no clue.. i don't see that kinda stuff often.. i may have seen 1 of your boat in my life... but i'll take a peak on the shelf.. but the more important thing is, what motor package... that can easily be obtained literature-wise usually..
