Changing front wheel studs
EDdaTREE
Austintown, OHIO
I've got 3 bad lugnut studs on my front axle...the lugnuts won't tighten up. I changed the rear ones before using the old "knock em' out with a hammer and pull the new ones in using washers and tightening the lugnut" method. How hard is it to do the fronts? Do I have to just pull the hub and rotor assembly off the spindle? Or do I have to split the both of them? Or is there a way to punch em' out still on the truck? Thanx for any help, and HAPPY MUDDIN'
Do them the exact same way as you did the rears,, just pull the tire,, knock them out the back and suck 'em in with an impact wrench.
Todd 78/87
Alaska Bound
Yes you have to pull the rotor off the spindle to do this.I just did all six on one end when i lost my wheel.Not good!!Brady
Brady is right. We had to replace all mine in the front before we slapped the 35's on my Jimmy. You have to remove all that stuff to get to them. Then after that you just punch them out and put the new ones in. Good luck man!
Alex
Wichita, KS
What me get stuck? NEVER!!(Famous last words)
