changing glow plugs
07 grizzly700 BE
Registered Member
florida
So yesterday i had some time and started replacing de glowplugs with Delco's. I started with the 4 front cylinders , wich went pretty smooth. But then i started trying to remove the other ones, and it seems i can't get to fit my wrench good enough to remove them. Did any of you guys have to remove some parts from the engine bay to get to the plugs ? Because some are in a really tight space, where it looks impossible to remove them. Or do you you have to remove some from underneath the car ? Any advice would be appreciated!
Thanks in advance
Matt
Thanks in advance
Matt
Are we talking 6.2 or duramax?
On the 6.2 the rear ones are easier to acces from the wheel well side.
I did remove the inner fender once to have better access but I also have a turbo that makes things even tighter.
