accidently broke window in pass. side door...is it hard to change out or would it be easier finding a new door...
yep...good thing this is goin on my beater...so it bein straight and lined up dont really apply...as long as it shuts...and the window rolls up and down...im probly jus guna get a beat up door...hopefully under 30 bux.... the door thas on there now is really stiff when it comes to rolling up and down the window....i think im guna start lookin for a new door...thas why i started the olive drab thread...i didnt like how the color turned out on my truck anyways..I have removed the glass on my truck before. It is not real hard to do, but you should have someone help hold the glass while you unbolt or adjust the window mechanism, and be prepared to spend some time maneuvering the glass in and out of the door. I don't remember the exact way to pull the glass out. You will also have to be careful not to scratch the new glass as you put it in. I had my glass replaced by a shop, after my truck was painted. I think I paid less that $100 per side for parts and labor, and it was worth a few bucks to have a pro do it.
If you change the whole door:
your paint may not match
you may have to unhook and then reconnect wires for locks and windows
you will have to get the adjustment correct on the hinge bolts
change the key lock from the old door to the new one
make sure that the used door has a good latch, window regulator, and weatherstripping and find good glass in a used door
You should get a price for the glass by its self and also a price with installation. Then do what you can afford. Or, replace the door if the above items will not be a problem.
Good luck
I ended up grabing a differnt door out of my scrap pile. I tried again to replace side glass a few years later and was succesfull at it. Still took a decent amount of time.
