Changing rear gate lock cylinder. k-5(m1009)
muddermilitia
ThatTrazerGuy
NE Illinois
Awhile back I tried rolling my rear window up and felt the handle get tight for a sec then totally disengage and i could freewheel it. I put the key into the lock and turned. When I pulled the key out, it took the cylinder with it.
So since then I have been using a big screwdriver jammed in the hole to put the window down/up. I finally got tired of that and today I went to buy a lock cylinder. When I swap this in will I need to remove the entire handle assembly? Thanks
Technical Manual 9-2320-289-20, M1009 CUCV. 16.4MB PDF Manual. Sorry I had to use Badongo, but its free with no acct. Almost a direct download for you.
From the few minutes looking for the task or simliar, I found the entire rear gate lock assembly removal/install, covered in Para 10-22, Page 10-81. I think this is what you're asking for ? If not just let me know and I'll look some more. :popcorn:
As for experience in completing the task - I got nothin.... :dunno: CUCVs simply get driven into the ground now, then auctioned once they quit being functional. The gov doesnt fund their up-keep anymore (In a major sense of the term).
Good luck !
Troy B
Ft Hood, TX
Thanks for the help, I will download that once I get home from work and report back
