Changing seal on t-case
az84chevy
What is involved in changing the seal on an np 208 that connects to the transmission?
Seal change
You have to seperate the T-case from the tranny, and then it's pretty straightforward from there. You have to do about 2 hours work to do something that takes 10 minutes, basically.
Change the rear seal and bushing too
Might as well change the rear seal and bushing while you are at it. $12 from Napa.
I alreadfy have the t-case out. Just looks like taking the actual seal off is a pita.
