Like the title says, I'm tackling this this weekend. The old K5 has a pretty serious oil leak and I'm pretty positive the sender is leaking. It seems like a pretty straight forward job, the only thing I am worried about is taking the distributor out to get to it. Is there anything that I need to worry about before I do this? Should I make sure the engine is at TDC on cylinder 1? Or just mark it with some paint and drop her back in?
..I was very surprised it wasn't leaking,or had not let the hoses blow off the fittings...those aluminum fittings can develop a pinhole too,and let a nearly invisible stream of oil squirt somewhere far away,fooling you into thinking the leak is elsewhere..
