Changing tranny crossmember w/out dropping tranny
PetaKane
Oklahoma City OK
This won't harm anything will it? 400 tranny/208 case, I have to put in my old crossmember since the new one doesn't clear the front driveshaft. Just wanted to ask so I don't mess anything up.
No, it shouldn't hurt anything. You could put a jack under it if you're worried, but the motor mounts and t-case crossmember will hold it up while you remove the tranni crossmember.
Thomas.
Uhh-oh, my transfer case crossmember is missing, I've got a crossmember where the tranny and t-case mount together, nothing else. But I'll use the jack just in case. Thanks
I would support either the case or tranny (as close to the middle as possible) if you're not taking out the adapter.
If you are taking out the adapter, that's a different (more complicated) story.
No problem doing this. This past weekend my transmission was held up with a jackstand for a day until I could get the crossmember in place with the new tranny mounts. I have the back crossmember, but it doesn't support the t-case (I assume this is normal). There is a gap between the back of the NP203 and the crossmember and it does not touch. The only support is both sides of the engine and two mounts where the transmission and t-case match up (under the adapter).
DOH! What was I thinking? LOL ... yea, ummm .... that's right, there's only one crossmember under there /forums/images/graemlins/tongue.gif
I agree, support it with a jack. I just removed mine on Saturday when I lowered it. I just put a jack under the back of the t-case and it was fine.
Thomas.
