So I finnished the build on this truck 6 or 7 years ago and its time for some chanages , I can't leave a good thing alone ! I am finally geting around to installing my magnum box after it sitting on my bench for almost two years . The best part is I eliminated my adapter and coupler so the magnum will only make the assembly about 3" longer than factory . The last time I wheeled the truck I junked out the front 1350 double cardon so I figured it was a good time to do the swap with the drive lines needing mods and all . There are lots of pics of the original build in my profile . I removed the case and completely disassembled it , had the input baring bored out then sand blasted it . I panted the case and started asembling it with new seals and ord shift rails , this is how far I got today.
