Jester1
Was out hunting today 30 miles from home and had the batteries not charging light come on. Saw lots of deer no elk. Started for home ASAP and noticed that light and message went away at 1800 to 2000 RPM. So kept manually shifting to keep the truck in the needed range and made it home. '05 Chevy D-Max K2500 HD.
Suspect is alternator. Checked all connections (tight) and checked voltage at batteries and alt. (12v) at idle. No climb in volts with reving. Truck off batteries climbed to 12.4v. Anybody else run into this? Just want some input before tearing apart and spending money.
Thanks Guys.
Thanks Guys.
