Cheapest ~15" travel front shocks
lochenjons
Santa Cruz, CA
I need some front shocks for my 52" swap. I was originally gonna go with my old 4" lift rear shocks I had lying around, but they are only 10" travel and after rereading every single 52" thread I found 15" travel is needed or a minimum of 14". Soo where can I get some for cheap?
nova just found a set of pro-comp es9000's with 15.5 inches of travel for 40 a piece at summit. Be worth checking out.
Hmm... I cant seem to find them with that much travel on their site
I got the second ones: EXP-936000 because it is more like other shocks in length and because it holds more oil. This means they run maybe only little, but still cooler. They also have 15.520 in travel verse 15.420. both are a little much but if I'm getting them for travel, I figured .100 more travel, runs cooler, dimensions are closer to high end overall lengths, and cost the same, why not get them.;)
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EXP%2D936000&N=700+0&autoview=sku
