Cheapest under 35" Tire
Big91RustyBucket said:
Looking for an aggresive tire in the 31-34" Range. Looking to spend no more than 155 Per Tire. Idea's . Also I only need it to last till winter time.
Thanks.
How many miles you going to put on it from now till then? 10k or less, I`d get some 34" LTBs, 10k or more, 33x12.5 TrxUs MTs.
I have a set of Kumho mud terrains on a jeep. They are 33's and cost about $100. They make two kinds, I have the Road Venture MT's and they are a little knobber than the other version. I bought them about 4 years ago from tirerack and they are still good. Even though I don't have a lot of street miles on them. They have been good in the mud/sand. So, I would check them out if you want a cheaper tire.
They must have gone up http://www.tirerack.com/tires/Compa...width=33X&ratio=12.5&diameter=15&startIndex=0
x2, I have good things about the LTB. I had 35" Trxus MTs on my 89 k5. I really liked them.
dunlop mud rovers. my 33x12.5r15s were $132 at discount tire. i love them. they look cool and are good on the road and even better offroad.
I had some of them before. $94 a tire at sam's. Had to many issue's with them
got 15k out of them . But my buddy won rtcc on 35" Mud rover's. Smacked the guy's with 39" bogger's ass's.
maybe i should have mentioned that price was AFTER road hazard waranty, installation, balancing, etc.
what issues did you have? this is my first experience with them, but a friend had the dunlop rover RT (i know, not the exact same tire) for about 40K miles and liked them.
why not try to find some used tires? I'm sure for that size should be pretty cheap since most people ditch the 33's and such for larger tires
http://high-tec-retreading.com/DesktopDefault.aspx
33-12.5-15 $80
35-12.5-15 $95
I doubt you'll find a better price and they will wear longer than any of the others you're looking at. The tread will be Dunlop Mud Rover, but the sidewalls can be whatever radial you want (if you're willing to wait for it). Typically they are built on Goodyear MT-R or BFG carcasses, stuff like that. If you call they'll tell you what they have in stock.
Plus check out the $150 37's coming soon.
