thirdstreettito
Registered Member
How do I check for a dropped cylinder?
The diesel equivalent of pulling a plug wire to check for a miss is to simply crack the injector line at the injector until fuel pees out. If the cylinder drops out you know that hole was firing. If no fuel pees out when you loosen the line, then you not only found your dead hole, you also found the (extremely unlikely) cause.
The best part is that there are no worn plug boots that zap your a$$ when you pull them off![]()
NO spark,yes,but ,instead,there is about 1500 psi of diesel fuel ,that can get squirted right into your bloodstream!..be careful!..![]()
1500 psi wouldn't even unseat the injector needle.
those old IDIs run around 14,000psi injection pressure. just so we all know what your handling. no something to be scared of. just respect what your doing.
modern DI pumps are around 18,000psi injection pressure.
and commonrail injection is in 22,000-25,000psi injection pressure.
