Check my gear contact pattern please
Scuba Steve
Registered Member
Fort Bragg, NC
Like I said, tell me if this is good or not. It is a 14ff with detroit. Bearing preload was 31 in lbs, backlash is .005 at the lowest spot and .008 at the highest. The average backlash was .006-.007 in most places. Shim was .010
Coast side
Drive Side
Is this housing out of the vehicle?
How did you hold the pinion while setting the preload to the crush sleeve/pinion bearings?
76 zimmer,
Yes it is out of the truck. I held the pinion bearing carrier in a big vise and held the pinion with a big c clamp. I tried using a pipe wrench but did not have one that fit good. I then hit it with a impact, trying not to go to far like i did the first time.
thats what I'm worried about too, I talked with a couple people, and they said start with the old crush sleeve first, and only if you have to, use the new one.
I've also read about using a press to start the crush on the new sleeve.
Its new to me, so we'll see how it goes here pretty soon.
I tried using a press with a piece of exhaust pipe but it crushed before the sleeve did anything at about 11 tons. I am in the military so I used the auto craft shop on post. They had a 3/4 impact, but my 1/2 IR impact did a better job. The crush sleeve breaks fast. It will hold steady at about 5-10 in lbs and then jump to 25 before you know it. I wrecked my first one. It was only a $33 mistake.
I just realized how big the pics you posted are:eek1:
I thought the pattern looked deep at first, but after zooming in on the last one, the pattern looks god there. I would run it like that.
Ughhh you never use an impact gun to crush a sleeve. Thats a good way to ruin them. Get the right tools. A 4 ft breaker bar and the proper tool that threads into the yoke to stop it from spinning.
As said it should take 8-12in pounds to rotate rear. You need an old school mechanically type torque wrench.
this threaded tool is the one in the GM service manual that bolts to the yoke?
