Rolled
I am placing a pretty big order for my brakes and both diffs. I would like any opinions on any parts I left out. Its been a while since i dug into the diffs and would not be surprised if I forgot anything.
I know its impossible, but I am hoping to get my order 100% the first time
so I don't have to go back to the parts dtore the usual 5 times lol
Here is the story. I am replacing all servicable parts in the diffs except the gears, pinion bearing, axle bearings, and front axle diff seals. No parts that require setting up the gears... I am also replacing the braking system except the vac booster, lines and the proportioning valve.
It is my goal to replace everything except what I noted in red.
Here it goes:
brakes
2 rotors
2 drums
2 calipers
2 wheel cylinders
pads
shoes
master cylinder
That should be it for the brakes. Pretty sure I did not miss anything
rear diff
wheel bearings
tube seals
pinion seal
gasket
gear oil
I think I am ok here too
front diff and related parts- here is where I am a bit cloudy
2 upper ball joints
2 lower ball joints
front drag link end
rear drag link end
left and right tie rod ends - are these called something else? partsamerica.com on lists parts for 2wd but they are listed as 4wd...
2 inner bearing cups
2 inner bearing cones
2 outer bearing cups
2 outer baring cones
2 seals -any help on these. The site lists them as $3 each but the last time I bought some they cam in a kit with a couple pieces. I can't really remember. Do you?
2 front axle ujoints
pinion seal
diff gasket
gear oil
thats all I can think of for the front. Am I missing anything?
2 ujoints for the rear drive line.
none for the front since I am getting a new dline made
That is all I have on my shopping list for now. Can you think of anything else I should add while I am at it? Most importantly, did I overlook anything that will require me to tear appart the front again? I really don't want to do it twice
Any help, advice, opinions, dreams, or scolding will be appreciated
so I don't have to go back to the parts dtore the usual 5 times lolHere is the story. I am replacing all servicable parts in the diffs except the gears, pinion bearing, axle bearings, and front axle diff seals. No parts that require setting up the gears... I am also replacing the braking system except the vac booster, lines and the proportioning valve.
Here it goes:
brakes
2 rotors
2 drums
2 calipers
2 wheel cylinders
pads
shoes
master cylinder
rear diff
wheel bearings
tube seals
pinion seal
gasket
gear oil
2 upper ball joints
2 lower ball joints
front drag link end
rear drag link end
pinion seal
diff gasket
gear oil
Obviously brake fluid and not-so obviously, brake lube for the moving parts (caliper slides, etc).
