Looks like the entire spark table is advanced? It may be because of old XDF files around, some have main spark bias and some don't, if you take from one and pout in another you add 10 degrees.
Stoich is easy, find it, change it, burn new chip. Gasoline is 14.7, E fuel depending on content of ethanol is lower and 14.2 works well. This is a major flaw of people using AFR gauge to tune, even if it's set up right. Lambda works better. AFR gauges are not, they are Lambda controllers and signal is converted to AFR.
Old gasoline 14.7 AFR = 1.00 Lambda WOT power = .84 Lambda
E10 13.8 to 14.2 AFR = 1.00 Lambda WOT power = .84 Lambda
Your narrow band O2 sensor DOES NOT adjust to 14.7 AFR, it adjusts to Stoich of fuel. Which was 14.7 AFR when these trucks came out but fuel has changed since.
Look at you VE and Spark tables in Graph mode to see if any big dips or spikes. This thread is for another ECM but the procedure and theory is the same.
http://www.gearhead-efi.com/Fuel-Injection/showthread.php?1024-7747-ve1-ve2
BLM history average. Getting good data is also key. Some of your data is skewed because you entered PE and DE and DFCO. Start data log when warmed up and driven, 10% throttle till it runs out or safe, 20%, 40%, etc... steady state throttle. Look for sample counts and throw out any under 3-5. Leave a few minutes of idle at end of log for idle tuning.
Smooth table!
