rampage
3/4 ton status
I'm guessing because new vehicles don't use shims. I used the DIY4X shims as well, and one of the side effects is that the spring is angled, therefore so is the top spring plate. This can result in the nuts not tightening down completely square on the plate. You'll have to torque them considerably tighter than factory recommendations, or the differing forces applied will be suceptible to loosening the nuts as the forces of driving act on the axle. I had to re-torque mine periodically after the initial install. Now I check them once a month.
This is true for the passenger side of a D60 where it has fixed studs in the axle (which DIY4x has a correction for), but on a rear axle this isn't the case. The axle is being rotated, the u-bolts stay in the same position as does the spring plate. DIY4x does mill the center pin recess at an angle so the center pin sits flat and doesn't have uneven stress that you're describing.
I just torqued a shackle flip and DIY EZs and shim under my 'burban along with a 12 bolt. I'm making damn sure I check them often!!!
