Checking Caster
nvrenuf
Holy crap, it's running!
Mobile, Al.
So I put my angle finder on the driveway at the base of the tire, angle is -1°
I set the angle finder on top of the D60 king pin cap, angle is +10°
My GM service manual says the spec is +8° "nominal".
I think this means I need a 3° shim but that doesn't sound like enough. To eyeball my axle, the spring perches appear to be tilted rearward (approx +5°) when I thought they should be level.
Am I doing something wrong?
Don't worry about where the perches are, caster angle is caster angle. If the ground is -1* and the knuckle is +10* then you are right at +9* caster and i'd leave that alone.
Stock caster is 4-8 depending on variances and specific axles. The bigger the tire the more caster it will take to keep the thing driving straight, as Scott mentioned I'd probably keep the 9*.
If the ground is down -1, and the caster is +10, then they are opposite angles and you would have 11 degrees of caster. Unless you flipped the protractor around?
Still, unless you are having issues with front pinion angle, I would leave it alone. A little too much won't hurt, may even help, but too little will be very bad. But if you are having front pinion issues then you could easily shim it 3 degrees or 5 degrees and probably be OK.
And I agree, perches are irrelavent, caster and pinion angle are what matters, and caster is most important for the front.
Ok, I'll double check it again just for good measure but I may leave it alone then. I'm chasing death wobble and was hoping I had found a contributing factor.
Nope, extra positive caster won't hurt death wobble, may even help. As long as it is + caster, and the upper kingpin is behind (closer to the back of the vehicle) the lower pivot bearing. If it's the other way around, then you probably did find your problem...
Quote:
There is no caster in the rear, unless it's a steering axle.
I think what he means is that out of spring perches, pinion angle, and caster angle, caster angle is the most important.
I agree with both of you, and you both confirmed the points I was trying to make, thank you. :waytogo:
I added "for the front" at the end of the sentence because I thought someone would say, "no the pinion angle is more important in the back".
