These:
http://www.stronghandtools.com/build...ual_plates.php
I'm looking into machining myown version of the Stronghand type welding table plates to guys making their own welding tables can buy these and use then as a modular welding table setup. Would like to see if there is intrest for these at a more affordable cost. Anyone why has ever looked into these knows thre are pricy.
The Stronghand are 5/8 think steel and are heat treated and blanchard ground with 5/8 tooling holes only for their accessories. I want to make mine out of 1" A572 structural steel, but these will be A572 material condition. Just material strength only, which A572 is some strong steel. Much harder then you 1018 cold rolled steel.
My plates will have 1/2-13 class 2 drill & tapped thru holes, AND 1/2 thru holes, AND 5/8 tooling holes so they accept the Stronghand tooling as well. Mine will also have drilled and tapped holes around the periphery of the plate on the long side, so you can bolt them @ 90 degree's as well with out having to use angle blocks.
So you would only lose heat treating but keep the plate strength in the thickness. Would not be as hard a surface, but for the home shop fabricator guy, do you really NEED it? No, you don't. I've had my welding tables for decades and they are not heat treated.
Pleae, Let me know. I need all the feed back I can get from this. Plate size will be 1" thick x 39" long x 6" high. Or any custom length someone wants up to our mill capacity. Don't want to step the plate over to machine it. Let me know fella's. Thank You for any feedback given in advance!
