just had to test and fix a bad lands brand winch from the cheepy brand places .
this winch is used only for trailer pull on duty . it has been used less than 2 dozen times until a month ago .
the guy said it just clicks and nothing from the motor . well i started looking it over and removing the unit from the trailer . as i was un-hooking the batt + & N the neg terminal end fell off the cable with the heat shrink . .
so as i looked it over the wire was heavy corrosion . i cut it back 6" as its to long anyways and found the same problem . also there is no signs of copper . . . .
i cut the neg wire 2 more times and still solid corrosion and no copper color . . . . this is when i remembered the race car world stuff . . . copper coated aluminum wire for weight savings . . and this stuff was light weight and falling apart like dust . . .
so the whole winch got 3 new wires from relay to motor . then 2 new batt wires to motor and relay .all with REAL solid copper wire .
then to my surprise the winch worked 100% as it should .
just goes to show you why YOU GET WHAT YOU PAY FOR
spend cheep get cheep .
...and it gets used every time I'm in the shop). The winches I've heard some say work fine for them, and some say they break the first time using it (starting to wonder if some user error is the culprit of some of that
). Either way, HF has it's place for many of the tools in our shops/garages.
