I have a "Carolina" brand 4 ton one I may have used 3-4 times since buying it in the mid 1980's..a tool rental place bought a lot of them off one of the "gypsies" tool trucks from NC where they were made,I paid $200 for it still in the box,he had a dozen or more too--I wished shortly afterwards I went for a pair of 8 ton jack stands for another $50,but I get by with what I had found at the flea market..
Another cherry picker was given to me ,my brother in law used to help a realtor clean out homes for sale,and he's get tons of stuff people abandoned--I don't know what brand it is,but its as or more rugged as the Carolina one,and all I had to do was de-rust it and paint it,and add oil to the jack (could use another paint job now)....
I leave it outside to use unloading things off my pickup or move stuff around,and I had a pair of two truck dolly wheels I put in the rear leg square tubing,the dolly pipe stubs fit perfect in them,that makes it much easier to roll on the driveway or lawn ,I have towed it with my garden tractor dozens of times to move things like engines around the yard,out back to the shed..
I would say to get a 4 ton for the reasons already suggested--they not only lift more,you need the extra strength and stability when the boom is extended fully....
I had a 1 ton one I borrowed to pull a 454/TH400 out of a pickup and it was scary,the rear wheels wanted to go up in the air with the boom extended just far enough to get to the chain on the engine..had to stand on it while I pumped the jack up,and when I went to pull the crane away ,it dam near flipped over when the engine suddenly swung around once it cleared the radiator support..
I'm getting to the age I should have a setup like this..
Even better would be a mini-excavator,but that ain't happening unless I hit the lottery..
. Not all their stuff is junk.
-so it can only be used outside,unless I were able to take it apart and re-assemble it inside..there is no means to lift it in the garage..
