chevette lines
bigjbear
1 ton status
Marietta GA
After searching I could not find the answer, so...
Are the 79 Chevette brake lines 10mm or 7/16 at the banjo fitting? I've got 10B calipers w/ the 10mm line. So if that is not going to work I need to know, TIA!
IIRC the chevette lines use a 7/16" banjo bolt so they won't work for you.
bendix 77227 rear rubber brake...i have this saved on my comp and iirc, its the part # kert gave me when i ordered my brackets
I'll assume that you are looking for short rubber lines for a rear disc...
'84 Cavalier front lines are about a foot long....used two right side ones on my rear disc with 10 bolt metric front calipers.
less then $10 at local parts store
Yes, thank you for the help.
I can't remember which side I used, but one side has a metal bracket wrapped around the rubber line which I didn't need/didn't feel like removing before my application use. Just look at both sides and decide which one you like better.
