chevy 8 lug vs dodge 8 lug
buffblazer
Fort Collins Colorado
the d60 im looking at is out of a 80's chevy mil truck, and the d70 is out of a early 90's dodge van.
both of course are 8 lug, but will the pattern be different? i need to order rims and i just got to thinking about how the spacing may be different.
oh good that makes me feel better, i was worried that i would have to screw around with different wheels and when i went to rotate i could only go side to side.
The only thing is some of the old Dodge stuff used 1/2 inch studs instead of the 9/16 like the Chevy 60. I am not sure if this pertains to rear axles or just fronts.
The hub on a dodge is bigger so if you want to order rims, make sure they are made for dodge.
They will fit on chevy.
well i like the 03-07 chevy wheels look like for the 3/4 trucks and i was wondering if the hub holes will be big enough to fit my dodge d70
also i was told the lugs may be a bit bigger on the dodge than the gm lugs even though the pattern is the same, will the wheels allow for the lugs to fit through?
i figured they would since when i shop for wheels they all kinda have the same but it was mentioned above that the dodge may have 1/2 lugs and im afraid they wont fit through the wheel holes.
