Chevy '92 SAS Blazer Parting OUT !!!
Eastcoast 4WD
Northeast PA
In an effort to build a new shop tube rig we are parting out the 1992 Blazer known as Big Sexy. The Following is a rap sheet of parts and asking prices. This is a 1992 Chevy Blazer with a 1996 K30 5.7 Vortec 4L80E Trans. All Prices are posted as or Best Offer. This truck was overhauled last spring and most parts have less than 6000 miles on them. I have many other parts not listed e-mail for needs.
Dana 60 Deadenbear Knuckles - $500 SOLD
Dana 60 ARB Air Locker 3.73 and down - $500
Dana 60 Hysteer Arms w/ Tie Rod and Draglink - $300
Complete 203chevy and 205ford Doubler w/ shifters - $1400
4L80E Trans 4x4 Version 30,000 - $800
1 pair 39.5x18x16.5 TSL Swampers 50% on Rims - $200 SOLD
1 pair 38.5x15.5x16.5 Boggers 50% on Rims-$200 SOLD
Off Road Unlimited Solid axle Swap Kit - $500
PSC Ram Assist Steering kit (Box, Pump, Ram Resivoir, Lines) - $500
4 Bilstein 5150 Shocks - $200 SOLD
ARB Compressor - $100 SOLD
Bush Wacker Cutout Flares - $175 SOLD
Front 4" Lift Skyjacker springs - $100 SOLD
Rear Offroad Design Shackle Flip - $90
14 BoltFF Rear Axle Large slide off Drum type 5.13 & Detroit - $900
Warn Enforcer Winch Bumper with Brackets and Caps - $350
Selling the engine?? Mabey a combo with the engine, trans, harness and computer??
Maybe a hijack but can you point me to pics of this 92 project? Just curious, not in the market for parts. Thanks.
b454rat said:
Is that front and rear fender flares?? If so then put me on the list.
Yes, thats the price for all four cut out flares, they are coated in herculiner to be crack resistant. This includes all the mounting screws and covers. All you need is some pop rivits and make a couple of brakets, or buy a hardware kit from bushwacker.
Engine is not running currently, I think the timing chain snapped. I went to start it one day and it made funny noises. I pulled the driveline from a truck that only had 35,000 miles on the rebuilds(Documented). I put about 7000 miles on it since I had it and it ran well. So I belive there to only be a minor problem. This being the case I would like to get $2000 for the engine, trans, harness and computer. That being said I would be willing to adjust the price down if it is found there is something major wrong with the engine after I pull it.
Do you have the stock rubber fender liner deals (splash guards) for the front?
I need a set.....
what length are the 5150's, how much travel?
how much for the pair shipped to 06375
RGV72BLAZER said:
what year will this work on? made just for 4wds??
It is the 4x4 version. As far as I know the brackets will fit a 2wd or 4wd frame. The difference is the 2wd version of the brackets have a crossmember linking the 2 sides together. On the 4wd frame there is a bib crossmember where the lower control arms mount to. The 2wd frame does not have this, so the 2wd sas bracket has a crossmember linking the brackets. You can view pictures of the brackets at www.offroadunlimited.com .
I'm lookin for close-ups of the brackets if it's not too much trouble.
