Chevy and Dodge 60s??
sapper
NoVa
Are they the same on the outers?? and if so would chevy hubs, rotors and calipers be the same? thanks:confused:
60 info
spring pads off just a bit. chevy used pigest thickness rotors of all 3 . most dodges till 90s ext hub . if needed just switch the hub assy and reuse all break parts the calipers are the same also. if swaping dodge to chevy the steering arm rod taper for drag link is smaller than gm. have machined to size or use gm arm on dodge axle.:grin:
