chevy d60
muddybuddy
1 ton status
Northern, VA
chevy D60 SRW with 4.56 gears with new bearings and seals. its been sanded and painted and has stock lock outs and non-neck down shafts. needs a tie-rod (i might have one, ill check and see), brakes are good, just surface rust from sitting (truck has been parked) might need to be turned.
$1100
ive also got a sky hi-steer/cross-over arm with studs as well as a 2wd box, pitman arm, draglink and 1.5x8" hydro-assist setup for it with hoses and fittings, all you would need is draglink ends and the tapped steering box caps and you'd be ready to go. ill throw that all in for an extra $300
located at 22039
