Chevy Dana 60 Front Axle Truss and Steering Mount
SKU MB4004
Only $499
The Motobilt Chevy Dana 60 axle truss is 3/8" P&O Steel for the main structure. The truss spans the length of the axle. Included is an integrated hydraulic ram mount for full hydraulic steering. The design is meant for a 2.5" double ended ram. The ram is completely protected from underneath with a full skid plate to keep it safe from the rocks.
The truss and steering ram mount are tied in together and a mount for a small clevis shackle is located on the front center of the steering ram mount. This mount is used to connect your winch to be used as a "Suck down" winch point.
The entire system is designed with key way fitments to ensure a true and straightforward install.
Professional welding is required to install this system properly.
We also have additional mounts for coil overs, link tabs, and hydraulic steering rams available for purchase separately as they are not included with this kit.
SKU MB4004
Only $499
