I want to put a dana 60 in the front of my blazer, I have a chance to get a dana 60 out of a 92 dodge single rear axle truck for payment on storing a buddy's truck. What is the difference in a chevy and a dodge dana 60? Thanks
91+ should be internal hubs. My early (non inter-cooled) 91' had internal style.
Only -89 and older had external hubs.The big downfall to most Dodge D60's is that the vast majority use external hubs that are more prone to failure
They changed to dana 60 and the A518 overdrive trans in mid -91.AFAIK, the D61 was only used in the early Cummins trucks (89 only?) and definitely only with the 727 auto. So, IMO, if it's a 92, it would be a D60 and not a D61.
dodge arm for stock steering is better once you have it redone to tapper on the top for the drag link . its like a factory raised arm then .
I'm not sure how this affects turning radius one way over the other.was gunna ask about this
the chevy arm has an offset towards the rear while the dodge is straight out, pointing at the engine. It shortens the draglink 2-3" which sucks, but can work.I'm not sure how this affects turning radius one way over the other.
