Chevy Dana 60
deadlew
Williamsburg, VA
Chevy Dana 60 with Ford SRW outers 4.10 gears. Axle is dissambled, but has all parts to complete except rotors and locking hubs. I would replace the king pins, rotors, wheel bearings, u-joints and seals. List of parts included Chevy 60 housing, 4.10 gears, open carrier and spiders, pinion yoke, drive and passenger Chevy 35 spline inners, diff cover, (3) Ford 30 spline outers, Ford driver and passenger knuckles, (2) Ford spindles, (2) Ford SRW hubs, Ford driver and passenger caliper mounting brackets, (2) core calipers, stock Chevy tie rod, new spindle bearings and seals, (2) new axle shaft seals. $650.
Pictures available upon request. Located in Williamsburg, VA
PaulC
Someone school me, what's the difference between a van 14b and a truck 14b? I believe it only has to do with width, but I can't recall exactly.
yep they are slightly wider than a chevy SRW front axle
im going to talk to mike (scrappyk5) i may buy the van 14b if he ends up buying the 60.
I talked with the wifey this weekend and also thought about added costs and decided to pass on this. It just wouldnt be cost effective to go with this. sorry if this messes up your plans james.
