Always wanted to do 35 spline hubs on the K5, maybe kick down the take-offs to this. If the SRW and DRW are swappable that is....
Definitely a big block. You’d have to get casting numbers to verify exactly what it is but it looks like a typical truck 454.
Aluminum intake and red paint, definitely not original.
That cover plate screwed over the hole where a 4spd shifter would be makes me think the th400 isn’t original. I’ve never seen an automatic truck with a removable cover plate over that hole.
Maybe decode the VIN just to know what it originally had for drivetrain.
Concur on that! I don’t know what the spring pack would look like for the heavier trucks. Did not like the stacked blocks.hub/rotor is all that makes a dana 60 front different . so swap away .
looks like a 4" lift spring combo up front and scetchy stacked mess in the back . but looks good underside from what i see .
It could use a coat of carc 383 green paint. Awesome rig
The glass filters (there are 2) are going for sure. That engine bay will be nice to clean up.well gotta point out my pet peeve. If you get this truck redo the fuel line loose the glass filter and move it by the frame. Also those spark plug wires look to be for headers, stock Big block has long straight boots
I have a spare in Sultan, WA.was hoping to put a CUCV grill guard on it if it fits with the boxes. Do you know where I can find one?![]()
And good eye on the plates! I had to go back through and see where - and there was not much visible.....I see a Nevada plate on the back.
Where in Oregon?Yep, Nevada truck.
We are in California, moving to Oregon, so I shop for trucks in Nevada....![]()
