Chevy TPI 350 ??
riz
3/4 ton status
Wisconsin
Can I just buy a top end TPI kit and bolt it up to my engine? Is that all it takes......... I mean I know I'll need an ECM, computer , etc but do they sell a complete 350 TPI conversion kit anywhere?
RIZ :waytogo:
purty much...here's the best deal going for the ecm & harness...linky
The guys in the injection section are the shizzle with this stuff...spend some time there, you'll learn waaayyyyyyyy more than you ever thought you could on this stuff. :waytogo:
Yea, it's pretty easy, you just have to make sure you get the right lower intake. If you have the old heads you need the early style lower, if you have center bolt heads, you need the newer lower intake.
When I did mine I pieced the whole thing together, I didn't keep track of what I spent, but I'd imagine it would be just as expensive or alittle cheaper if you just got a complete system, and it would be less of a headache.
I went thru street and performance for my harness, and a new prom chip. They do sell a complete kit that supplies everything needed to put it in, the complete intake, throttle body, distributor, harness, all the sensors, etc.. I'd recommend them to anyone interested in swapping to TPI, a LT1, or anything else they support.
