Chinese headers
Kain
3/4 ton status
Lubbock Texas
I took of mr gasket headers when i got the Blazer these look better than those.
The collectors are 2 1/2 so if i get a reducer i can run em (i run 2 1/4 pipe)
the reducer i bought with o2 bung in it saves me 40 bucks
local exhaust shop want 55 to weld plus 16 for the bung
second pic is the collector flange diff headman verses chinese the chinese is thicker and stainless
the welds look good and its heavier than my hookers but when i pull em ill show the diff before install
probably tuesday
I still find it hard to believe that they are putting out an apparently good product, especially for the price.
@78K30 has a similar experience.
It's not perfect but if it fits I'll be a happy camper. It has some scratches from shipping but not a deal breaker it did one have 10 header bolts and you need 12 but I have stage 8 locking ones the collector bolts are stainless from the looks of it and I will be using those
I once said I’d never run headers, but some of these newer Chinese stainless ones are frickin good! I’ve got a set on my 92 and other than horrible plug access to one cylinder they’re great
just got all the adapters i need i think i need 1 clamp then ill put em on
if i dont need a clamp might be tomorrow
What's the individual runner diameter? Kind of wondering if plug and bolt access would be appreciably better with the 1.5" tubes compared to the 1.625" ones that are most common.
Not a whole lot of difference, but for bolt and plug access, you don't need much space to make it better.
The second bolt for #1 and #2 look pretty hard to access, especially with thicker flanges needing an even longer bolt. Maybe it's just deceiving?
That's the driver side and you have to notch the motor mount witch is no big deal will take pics when I do it
i am going to have to clearance the frame a bit on the passenger side just a tad
these 2 pics are the passanger side where i have to clearance it view from top and bottom
