Chiped pinion gear
mrbill
Sugar City, Idaho
I just bought a used 3.73 setup. Seems UPS was a bit ruff on it and the Pinion gear got lose. The out side tip of a few of the teeth were chipped, some quite abit. Just the tip and not to the face / wear surface. Is this going to be OK?
It'll be fine. You could grind that area off without hurting anything. Make sure any edges are smoothed over so they don't cut into the ring gear.
I ground five teeth of my DD's ring and pinion just so I could put my lockright in.
make UPS pay for it, then put it in, then you have xtrr cash
[ QUOTE ]
What Tim said. But, hmm, wonder how they did that. Its not like its easy to chip. Sure it wasnt chipped before UPS?
[/ QUOTE ]
i sold him the gears, i had an employee package them, apparently he didnt do a very good job. i hope they're still ok. they were in perfect shape before they went into the box.
I'm happy with the deal!! - Jonny-K5 has been very helpfull. The pinion got lose in the box and bounced a bit. Sounds like the chips won't cause any problem being out on the tips and not on the wear area.
they were insured, 100$ each box. if you can get it that would be cool.
[ QUOTE ]
[/ QUOTE ]
Actually the outer corners of gear teeth are pretty easy to chip. At work on Monday, I put a gear from the transmission I was rebuilding down on my bench (1/4" steel top). It slipped out of my fingers and fell approximately one inch to the tabletop, and 2 teeth chipped.
