Back when I was running carbureted vehicles, one of the first things I did when I got one, was pull the choke cap off and throw it away.
Then I would put on a manual replacement.
Since I grew up with manual chokes, I learned early how to crank a cold engine, and I just felt I could do a better job than a spring.
Plus, it gave me the option of a fast idle anytime I wanted it. If the air conditioning was not doing a good job at idle, or if I had left the lights on and wanted to help the battery charge, I could pull the choke knob out while pressing on the accelerator so that it closed the choke and put the idle screw on the fast idle step.
Then, I could let off the gas, and push the choke knob back in. That would open the choke all the way, but the fast idle would stay on until I hit the accelerator again.
I think the kit was about $10 back then, but I would usually buy a separate choke cable along with it, because the one that came with it was so cheesy.
It was dead simple to put on, but on my pickup, I had to reverse things since the clamp on the shaft would hit the underside of the air cleaner housing.
So, I had to mount the cable lever on the other side and let the clamp come off the bottom.
Which put a fairly sharp bend in the cable which was when I discovered it needed an upgrade.
