Chop or swap?
Swap or chop?
  • Chop the long bed
    Votes: 6 46.2%
  • Swap to the K5 frame
    Votes: 5 38.5%
  • I'm nekid
    Votes: 2 15.4%
  • Total voters
    13
  • Poll closed .
jekquistk5
Weld nekid
Pinckney, MI
Need opinions on what direction I should head in.
right now the truck is a long bed 3/4 ton, and its too long for tight trails. So I need to either chop the rear off or swap the cab onto a blazer frame that I already have. Plan is to go to coils fronts with 4 link and 64's in the rear and finally swap the 60 and 14 in. Leaning more towards the blazer frame so I can still somewhat have a running truck while I engineer and build the suspension.
thoughts?
Ive kinda been tossing around the same idea's seeing that I have a longbox, and they are excessively long and dont turn all that well.
Swapping frames would be a serious waste of time and a downgrade in strength. The blazer frame is a 1/2 ton rated frame while the 3/4 ton is a **** hair thicker I believe is the difference.
Either way its a serious time sink to swap everything over to a different frame when you have a perfectly good one you could cut down already.
Longbeds are way cool, but needs on the trail come first for many.
I voted to chop, because if your truck is already fairly sound, pulling the box, and chopping would be easier than redoing another frame to drop your cab onto.
maybe picking up a protools bender tomorrow as long as the dude calls me back :whistle::whistle: I see a truggy in my near future :)
