Chop saw tubing notching....
sled_dog
1 ton status
Austin, TX
Anyone link me to the thread or site that has the bit about chop saw tubing notching? I need to go make a crossmember and don't feel like sitting there with a hand grinder until the damn notch is perfect(I need a plasma cutter, smaller grinder, and tubing notcher). I just need to do 2 90* notches on some 1 3/4" tube and maybe some 1 1/2".
It's super-easy for 90* notches, just cut the end of the tube at 45*, then rotate the tube 180* and make another 45* cut. The two 45* cuts will intersect in a point - instant notch - then repeat at the other end. I'm looking for another good post on this - i know there've been a couple on here and POR.
Notches
Yeah I remember reading that thread, it was about 3 months ago. Have you tried search.BTW I live in North Wales. I hope you find it I would like to write that information down, just bought my son a chop saw for Christmas. Later J.
actually thats not the case...
http://coloradok5.com/forums/showthread.php?t=123969&highlight=chop+saw+notching
Found the thread. 28* is the base angle for 1.75" notch.
This has been comming up alot lately. Great info thanks for dirrecting me to the right place.
Im notching all my tubes in the truggy with a chop-saw. I like it better then a hole saw notcher.
I started doing the notching on my cage with a hole saw. Took a long time and was kinda messy. Started notching with the chop saw and it works 10 times better. I think there is a chart on pirate with all the different angles for the tube and joint degrees.
