Yes, see the blade coming off the center stud? Just push that connector with the orange wire onto it. That is the factory setup. You can ignore the outer blade as long as you make a secure mechanical connection to the metal dash. You may have to trim the center blade thing to make it work. Also check the fuse for the lighter - it may have been pulled or blown since the wire is dangling.Is there any other way to attach it?
