Queasyrida
Registered Member
My '90 Blazer is put away for the winter. My '93 Chevy 1500 4wd quit running. It was hard starting for a week, now it won't start. Symptom: When it would start, it would crank 10-20 seconds and then fire. Black smoke would come from the tail pipe, and then shortly it would clear out. It ran smoothly and strong, doing a lot of snow plowing. Finally no start. Checking on line, the temp sensor is frequently a failure, causing the ECU to "think" it's 40 below, causing a very rich condition. I changed the sensor and plugs as they were fouled. Still no start. I tried ether and dumping a little gas right in the TBI. Didn't fire. I'm guessing no spark. Not familiar with ECU controlled ignitions, not sure where to start. It was getting dark and no one around to help me check for spark. I need advice how to systematically check my ignition. It's a 350 w/5 speed manual. Thanks!
..wasn't my smartest investment really,and I know better than to leave a vehicle sitting for long too..
