CHEVYDADDY
had dummy lights so opt. out four famous triple guage setup. so bright ideal take dummy light out and put new gauge in the dash! so started with battery gauge i took apart the dash leaving my speed o and gas gauge attached. took dummy light out and used standard hole to run wires trough. grounded gauge on fire wall/pos went to key hot fuse.(yes stuffed in with the fuse) i have done this before but dont really like the idea. any other ideas? it is a DD! where do i go for the lights in the gauges? dummy light use circut board to light up how can i use this to my avantage? temp gauge is fine but still need lighting next oil pressure not there yet. i believe there will be some triming but going to do little as possible(i think)
