45acpJr
After shaving my axle I'm sure I got some metal shavings inside the axle even though I was careful. What could I use to flush it out? Would diesel work?
I just got done doing the same thing. I used compressed air, then brake clean.
Making sure to get all the nooks and crannies. Like the fluid return under the pinion bearings
For the tubes I have a piece of all thread with 2 nuts clamped around a small piece of metal. I wrap a rag around it and drag it up and down the tubes. Then brake clean.
Then I hand wiped it down with a cloth to make sure it was clean.
Show-off. So jealous.
