Cleaning garage! Shackle flip, springs, etc.
trollporter
Lady's Island, SC
Cleaning the garage! I have pics for every item if you need them.
-Used Ruffstuff 14bff spring perches, offset holes for 1" and 2"(bought from a CK5 member and cleaned them up) $15
-New SBC and th400(firewall mount) Lokar "style" dip sticks $30/each
-New Chevy/Dodge Dana 60 U-bolt kit $30
-Used 81-91 Chevy 6" front Pro comp springs(PN: 11511), i've got 2 new sets of bushings and a new set of frame bushings to go with these $180
-Used Class 5 hitch for a Dodge W250. Bought it new for my '92 Dodge and it was only on the truck for about 2 month before I did the dually conversion and went with a flat bed that had a built in hitch. I believe it should fit any 150-350 on the first gen years. $80
Troy Porter
1-803-834-9880
[email protected]
Can I get the Part #'s from the lokar stuff. I want to see if they also fit my 4l80E and Cad 500 motor. If they do I want them.
Those Pro Comp springs will also fit 73-80, only difference is in the 88-91 straight axle trucks, they use different sleeves and bushings.
90K5Blaz: The dip stick are actually Lokar knock offs, that's why i said "Lokar Style". I'll look when i get back home on mon. to see if there are any part #'s
RayJimmy: Thanks for the info. The 2 new sets of bushings i have are for 88-91 models.
