elks
I am putting in brand spanking new axles shaft into my dana 40 front the 72 blazer I own. I noticed that when I removed the old axle there was some significant sand that came with it. This was not from with in the pumpikin, but sitting in the axle housing. So when I get everything taken apart how should I clean it all out? I was thnking about lifting one side extra high and trying to spray it out using gravity to pull the water and dirt out the end. I also thought about air, but I do not have a very big compressor, but can get about 100 pSI.
How should I try it? PS Inner axle seals are not looking and are not going to get replaced unless I screw it up.
last time i give him a good tip
