scored this dana 60 for parts a week ago .
its got bad gears and frozen calipers . broken home made studs for pass side leaf spring plate . and the driverside spring pad is all messed up .
but anyways figured i would show some of you that have asked before how to get the broken stuff out of the hole.
someone used threaded rod inplace of studs or bolts.
the rod that was left was bent up BAD . scary stuff other people do .
