vandelay industries
What are you guys doing as far as cleaning the oil pan, timing cover, valve covers etc. both outside AND inside?
I have a little parts washer with mineral spirits that I use for most cleanup work. I also use purple power, brake cleaner, engine gunk or whatever else is around with a variety of stiff brushes with a hose or pressure washer. Hot water helps a lot, hook a hose up to your water heater.
Castrol super clean 4-1 with water in plastic tub then I put in a bucket heater over night and the grease pretty much falls off.
This stuff is amazing. I was cleaning valve covers from a dirty motor and carb cleaner, brake cleaner, gasoline, simple green soaked for a day would do almost nothing. A can of oven cleaner from the dollar store and the crud ran off like water. I wouldn't trust it on painted stuff or a beautiful polished finish, but for the baked on crud it's magic and cheap.Easy off oven cleaner, cheap and works great.
Yes, I used Easy - off on my entire engine on an old truck I recently bought. The caked on grease and grime came right off ,after powerwashing. Unfortunatly the paint came off as well. It will also discolor aluminum, and take off any anodizing.This stuff is amazing. I was cleaning valve covers from a dirty motor and carb cleaner, brake cleaner, gasoline, simple green soaked for a day would do almost nothing. A can of oven cleaner from the dollar store and the crud ran off like water. I wouldn't trust it on painted stuff or a beautiful polished finish, but for the baked on crud it's magic and cheap.
Easy off over cleaner too but I do it at the car wash in a manual wash bay.
