BadDog said:
Ken, ah, I see. But AFAIK, there are 2 main AV gas choices. One is just high octane without the automotive smog additives. The other, Jet-A, is pretty much just Kerosene. Is there another? Kerosene would be relatively mild on the tubing, and the other does not have some of the additives that could do damage like detergents, oxygenating additives, and/or alcohol.
OK, going
way off topic for a moment...
Avgas and Jet A are vastly different animals:
"Avgas" is aviation gasoline for reciprocating engines. Used to be available in many grades, but now the only common one is 100LL (100 octane [lean mixture] with a Low Lead content). It has some additives in it (antifoaming, mild biocide, a little detergent), but not as many as the pump gas for cars.
"Jet A" is a type of aviation turbine engine fuel. Three types are available; Jet A (most common), Jet A-1 (semi-rare), and Jet B (very rare). Jet A and Jet A-1 are basically kerosene, with lots of additives (antifoaming, anticorrosion, biocide, others), and Jet B is a blend of kerosene and gasoline with all the Jet A additives. Military fuels are a little different, but basically they stack up like so: JP-8 is Jet A, JP-4 is Jet B. JP-5 is different enough that there's no true civilian equivalent, although it's freeze point is similar to Jet A-1.
Turbine engines will run on avgas, but the lead will leave deposits on the power turbine blades, and reduce engine efficiency. Recip engines (with a couple exceptions)
will not run on Jet, and this has been the cause of numerous crashes over the years.
The homebuilt/experimental aircraft community has been playing with alternatives to these expensive fuels (both avgas and Jet A are running well over $3/gal for the General Aviation community...) for a while now; there's quite a few homebuilts running on regular pump gas, along with a diesel engine for the homebuilt market designed to run on Jet A. Most ultralights and powered-parachutes run a Rotax engine on pump gas.
I personally think the Bing will be your best bet; it's made specifically as a fuel line. But hey, I'll stop trying to sell it to you, so the decision's yours.
