clearance issues with....
TXsizeK5
College Station, TX
a 6" lift and 42x15/15's.
Do you have clearance issues with the frame/firewall? would moving the axle forward be required? Any pics?
I already did a search... any pics?
I have 38's & 6" lift w/ 2" body lift, I will be removing the 2" for a 1" ORD body lift soon. I have enough room for 44's but the 44's hit the spring pak when turning, 42's just clear.
[ QUOTE ]
[/ QUOTE ]
if you move your axle forward it will help clear the firewwall, and if your tires are hitting the frame you may have to much back spacing.
