brandoneh
I'm having trouble finding a solution to making these headers fit.
I purchased these headers after seeing them on a fellow members thread. AJ72's build. http://coloradok5.com/forums/showpost.php?p=2801090&postcount=247. I was hoping it would be all good on fitment just like it shows in his build.
So I picked them up for a hefty penny and have had a lot of issues. I had to trim my frame rail immensely to get the first two tubes to clear on both sides. Also, with the diy4x crossmember setup it seems every time I pull the motor, trim, put it back in, the motor is in a different place. Makes things difficult and have to trim a different place everytime. The frame rails are trimmed now for clearance, and will have it boxed it where the cuts were made to make up for the loss of strength. My issue now is I don't know what to do with the shackle bolt hitting the tube on the pass. side.
I tried the ratchet strap idea that I have read here. I was a little nervous with ratcheting the headers as they were bolted into my aluminum heads, not quite sure if I would damage the heads. I was able to move the header a wee bit until the strap broke on me. I'm not sure if these headers will bend enough because of the thickness of the tubes. I also trimmed the grade 8 bolt head after swapping the way it was installed (used to have the bolt on the outside and the nut on the inside).
I also made a dimple on the header but it seems like its just not enough. It looks like on AJ72's build the motor has quite a bit of slope to his motor/tranny. Sitting under the truck I was wondering if I could drop the tranny enough more to provide more slope and get that header to clear. I believe where I am at now is a proper angle around 6 degrees or so. But I have ran out of ideas and am asking for some help.
I've attached some pics to help get an idea. I'm also wondering if I should be more aggressive on the ratcheting/bending header idea. I'm sure I can get a bigger strap and give it a go, but should I be worried about the Alum heads? I also am not sure if heating it would be beneficial. And if I am to heat it, where would I get it hot at? It's the passenger side 2nd tube that is hitting the shackle bolt, but I just can't heat that part up to make the adjustment as they are all joined together at the end.
Open to any suggestions. Thanks for reading.
