Clip for wires into coil: 87 TBI
Vetteman61
Registered Member
Kentucky
Hello all,
I have an '87 K5 with the TBI. It has been dying lately and I traced it to the two wires that plug into the back of the coil. One of the plastic clips has broken and it won't plug securely.
Where can I get one of these clips to rewire and solve the problem?
Thanks,
Brandon
The broken clip isn't your problem, trust me. If you're driving along and the engine shuts off like someone turned the key off it us 99% of the time the ignition module going bad. They are a common problem with GM and I carry a spare because of how often they fail.
Thanks for the tip. That did turn out to be my problem a few weeks ago, but when I took those clips off one was very brittle and broke. It now has a tendency to not start and sometimes die. You can push that wire back in and it starts up fine.
Thanks for the website, too.
Brandon
I'm that other 1%.. :D
Well, here's a great module story for you:
My sister had a car fire in her garage and the smoke completely destroyed her whole house. Seriously, I never knew smoke could ruin that much stuff. Even the metal in the house rusted and pitted within a few days. Everything was SOLID BLACK in both stories. So anyway, I gave my K5 to my nephew until insurance pays them to get him a new car.
I first put a module on my truck to cure the dying problem. It didn't fix it. I put a coil on. Nothing. I put a TPS on. Nothing. Finally, I relented and put a fuel pump on. My nephew and I spent 2 days during the summer in the driveway with no shade in temperatures above 100 degrees. Seriously, any tool left outside of the shade of the truck would be untouchable within 2 minutes. So we finally get the pump changed. IT STILL DIDN'T FIX THE PROBLEM. Turns out the new module I put on first was bad right out of the box. Gotta love foreign made electronics.
Brandon
