Clocked 241's with the DIY clocking ring
wayne
3/4 ton status
Carlisle, Pa
Anybody using the DIY kit for clocking their t case? If so what set of holes did you use and how far is it tucked up?
I just used the first set of holes which clocked it up about 2". I have a tall adapter in there for now so that put the front output drop above the crossmember.
I used it on my 208. I clocked it up 2 positions. My tcase barely hangs below the framerails. I had to do quite a bit of floorboard mashing to get it in there with no body lift though.
Harley
I had to cut my floor boards with no body lift and half-clocked. I originally pounded the floor in, but the tcase would still occasionally bump the floor.
